Salta al contenuto principale
Casio A158W-1 Battery Replacement
Cosa ti serve
  1. Casio A158W-1 Battery Replacement, Battery: passo 1, immagine 1 di 3 Casio A158W-1 Battery Replacement, Battery: passo 1, immagine 2 di 3 Casio A158W-1 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Using the Phillips #00 screwdriver, remove the four screws from the back panel of the watch.
  2. Casio A158W-1 Battery Replacement: passo 2, immagine 1 di 1
    • With your fingers, or tweezers if available, remove the rubber gasket surrounding the base of the watch.
  3. Casio A158W-1 Battery Replacement: passo 3, immagine 1 di 1
    • Carefully remove the centerpiece of the watch from the casing.
  4. Casio A158W-1 Battery Replacement: passo 4, immagine 1 di 1
    • Using the Flathead screwdriver, push the four tabs located around the centerpiece inwards to open it up.
  5. Casio A158W-1 Battery Replacement: passo 5, immagine 1 di 2 Casio A158W-1 Battery Replacement: passo 5, immagine 2 di 2
    • Open up the centerpiece to reveal the battery.
    • Carefully remove the dead battery.
  6. Casio A158W-1 Battery Replacement: passo 6, immagine 1 di 1
    • Insert the new Cr2016 3V Lithium battery into the centerpiece.
    • Reattach the back of the centerpiece together.
  7. Casio A158W-1 Battery Replacement: passo 7, immagine 1 di 2 Casio A158W-1 Battery Replacement: passo 7, immagine 2 di 2
    • Insert the centerpiece back into the casing of the watch with the "front" facing down.
    • Position the rubber gasket back into place.
  8. Casio A158W-1 Battery Replacement: passo 8, immagine 1 di 2 Casio A158W-1 Battery Replacement: passo 8, immagine 2 di 2
    • After putting the back panel of the watch into place, use the Phillips #00 screwdriver to screw four screws into place.
  9. Casio A158W-1 Battery Replacement: passo 9, immagine 1 di 1
    • Finally, reset the Casio watch to the correct time.
    • Make sure all buttons are operational.
Conclusione
Libaan Major
Membro da: 09/10/21
193 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 20
Ultimi 7 Giorni: 138
Ultimi 30 Giorni: 658
Tutti i Tempi: 8,847
