Salta al contenuto principale
Casdon Dyson Ball On/Off Switch Replacement
Cosa ti serve
  1. Casdon Dyson Ball On/Off Switch Replacement, Battery: passo 1, immagine 1 di 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball On/Off Switch Replacement: passo 2, immagine 1 di 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball On/Off Switch Replacement, On/Off Switch: passo 3, immagine 1 di 1
    • Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
  4. Casdon Dyson Ball On/Off Switch Replacement: passo 4, immagine 1 di 1
    • Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
  5. Casdon Dyson Ball On/Off Switch Replacement: passo 5, immagine 1 di 1
    • Cut the two wires connected to the on/off switch using a set of wire cutters.
  6. Casdon Dyson Ball On/Off Switch Replacement: passo 6, immagine 1 di 1
    • Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
  7. Casdon Dyson Ball On/Off Switch Replacement: passo 7, immagine 1 di 1
    • Remove the on/off switch by pulling it away from the vacuum with your fingers.
    • Replace the faulty on/off switch with the new on/off switch.
    • Solder the new on/off switch's wires to the vacuum's wires using a soldering station.
Conclusione
Seldon Price
Membro da: 11/07/17
612 Reputazione
5 Guide realizzate
IUPUI, Team S3-G5, Harley Fall 2017 Membro di IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 Membri
10 Guide realizzate
Un commento
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,110
