Salta al contenuto principale
Casdon Dyson Ball Disassembly
Cosa ti serve
  1. Casdon Dyson Ball Disassembly, Battery: passo 1, immagine 1 di 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Disassembly: passo 2, immagine 1 di 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Disassembly, Casdon Dyson Ball Disassembly: passo 3, immagine 1 di 1
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Disassembly: passo 4, immagine 1 di 1
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Disassembly: passo 5, immagine 1 di 1
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Disassembly: passo 6, immagine 1 di 1
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Disassembly: passo 7, immagine 1 di 1
    • Remove beads from the container.
Conclusione
Altre 2 persone hanno completato questa guida.
Seldon Price
Membro da: 11/07/17
612 Reputazione
5 Guide realizzate
IUPUI, Team S3-G5, Harley Fall 2017 Membro di IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 Membri
10 Guide realizzate
2 Commenti
How do I get the handle out once assembled?
Carie McClendon - Replica
The fan to make the beads jump around no longer works….is there. Separate battery for that?
Kathy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 80
Tutti i Tempi: 12,356
