Salta al contenuto principale
Casdon Dyson Ball Air Cylinder Motor Replacement
Cosa ti serve
  1. Casdon Dyson Ball Air Cylinder Motor Replacement, Battery: passo 1, immagine 1 di 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Air Cylinder Motor Replacement: passo 2, immagine 1 di 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Air Cylinder Motor Replacement, Casdon Dyson Ball Disassembly: passo 3, immagine 1 di 1
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Air Cylinder Motor Replacement: passo 4, immagine 1 di 1
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Air Cylinder Motor Replacement: passo 5, immagine 1 di 1
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Air Cylinder Motor Replacement: passo 6, immagine 1 di 1
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Air Cylinder Motor Replacement: passo 7, immagine 1 di 1
    • Remove beads from the container.
  8. Casdon Dyson Ball Air Cylinder Motor Replacement, Air Cylinder Motor: passo 8, immagine 1 di 1
    • Remove four 9.2mm (0.32 in) screws on bottom of air cylinder motor mount using the PH00 screwdriver.
  9. Casdon Dyson Ball Air Cylinder Motor Replacement: passo 9, immagine 1 di 1
    • Remove one 11.5mm (0.45 in) screw in battery compartment using the PH00 screwdriver.
  10. Casdon Dyson Ball Air Cylinder Motor Replacement: passo 10, immagine 1 di 1
    • Remove the red fan from the motor by pulling the red fan away from the bead cylinder motor compartment.
  11. Casdon Dyson Ball Air Cylinder Motor Replacement: passo 11, immagine 1 di 1
    • Cut wires connected to faulty motor using a set of wire cutters.
  12. Casdon Dyson Ball Air Cylinder Motor Replacement: passo 12, immagine 1 di 2 Casdon Dyson Ball Air Cylinder Motor Replacement: passo 12, immagine 2 di 2
    • Remove and replace faulty air cylinder motor.
    • Solder new air cylinder motor's wires to the vacuum's wires which were previously cut.
Conclusione
Seldon Price
Membro da: 11/07/17
612 Reputazione
5 Guide realizzate
IUPUI, Team S3-G5, Harley Fall 2017 Membro di IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 Membri
10 Guide realizzate
Un commento
What motor is it?
Daniel Blakey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 305
