Salta al contenuto principale
Carrera Mario Copter Motherboard Replacement
Cosa ti serve
    1. Carrera Mario Copter Motherboard  Replacement, Battery: passo 1, immagine 1 di 1
      • Flip the quadrocopter over so that the underside of the device is facing up.
      • Unplug the battery cable from the socket on the quadrocopter.
      Chiedi a FixBot
      Aggiungi Commento
    2. Carrera Mario Copter Motherboard  Replacement: passo 2, immagine 1 di 1
      • Push the battery upward with your thumbs to loosen it from the tight slot until your thumbs can not reach the bottom of the battery anymore.
      Chiedi a FixBot
      Aggiungi Commento
    3. Carrera Mario Copter Motherboard  Replacement: passo 3, immagine 1 di 1
      • Pull the battery away from the slot to remove it.
      Chiedi a FixBot
      Aggiungi Commento
    1. Carrera Mario Copter Motherboard  Replacement, Motherboard: passo 4, immagine 1 di 2 Carrera Mario Copter Motherboard  Replacement, Motherboard: passo 4, immagine 2 di 2
      • Using the Phillips # PH00 screwdriver unscrew the four 7.1mm screws in the black circle base.
      • Remove the entire black circle base and flip it over so you can see the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. Carrera Mario Copter Motherboard  Replacement: passo 5, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Using tweezers remove the four white heads wires from the motherboard.
      • Be careful not to cut the wires plugged to the little white heads. Grab onto the plastic connectors if possible.
      Chiedi a FixBot
      Aggiungi Commento
    3. Carrera Mario Copter Motherboard  Replacement: passo 6, immagine 1 di 2 Carrera Mario Copter Motherboard  Replacement: passo 6, immagine 2 di 2
      • Using the tweezers remove the golden head screws that hold down the motherboard.
      • Hold strong the motherboard and pull up strong the head screws.
      • Be careful not to hurt yourself. You will need to try several times to remove those.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
UW Tacoma, Team S1-G6, Rose Fall 2017 Membro di UW Tacoma, Team S1-G6, Rose Fall 2017
UWT-ROSE-F17S1G6
4 Membri
60 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 36
Ultimi 30 giorni: 82
Tutti i Tempi: 849
