Salta al contenuto principale
Carrera Mario Copter Controller Circuit Board Replacement
Cosa ti serve
    1. Carrera Mario Copter Controller Circuit Board Replacement, Controller Circuit Board: passo 1, immagine 1 di 1
      • Flip the controller over so the underside would face up
      • Remove four of 7.1mm screws with a JIS #1 screwdriver
      • Remove two 4.0mm screws located on the handle with the JIS #1screwdriver.
      • Remove two 7.1 mm screws on the small area that stick out from the surface with the JIS #1 screwdriver
      • Use an extension with the JIS #1 screwdriver in order to get to the screws with yellow marks because they locate deep inside the holes.
      Chiedi a FixBot
      Aggiungi Commento
    2. Carrera Mario Copter Controller Circuit Board Replacement: passo 2, immagine 1 di 1
      • Remove the black case to access the circuit board.
      • Remove two 4.8mm screws on the circuit board with the JIS #1 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Carrera Mario Copter Controller Circuit Board Replacement: passo 3, immagine 1 di 1
      • Gently lift up the circuit board from the black case.
      • Use a soldering iron to melt the red wire while at the same time pulling it from the motherboard.
      • For more information on how to solder and desolder connections, please visit this guide.
      • Repeat the previous procedure with the black wire.
      • Gently remove the circuit board away from the case.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
UW Tacoma, Team S1-G6, Rose Fall 2017 Membro di UW Tacoma, Team S1-G6, Rose Fall 2017
UWT-ROSE-F17S1G6
4 Membri
60 guide realizzate
1Commento della guida
i don't have the receiver. what can i pair with?
Ali Ali - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 32
Ultimi 30 giorni: 63
Tutti i Tempi: 743
