Salta al contenuto principale
Caribou Coffee CC-EKV8SS7 Power Cord Replacement
Cosa ti serve
  1. Caribou Coffee CC-EKV8SS7 Power Cord Replacement, Caribou Coffee CC-EKV8SS7  Base Disassembly: passo 1, immagine 1 di 2 Caribou Coffee CC-EKV8SS7 Power Cord Replacement, Caribou Coffee CC-EKV8SS7  Base Disassembly: passo 1, immagine 2 di 2
    • Unplug the unit before disassembling to avoid electrocution.
    • Remove the five (10mm) Y screws from the bottom of the base. Three are in a triangle around the center and two are on the corners of the flat edge.
  2. Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 2, immagine 1 di 3 Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 2, immagine 2 di 3 Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 2, immagine 3 di 3
    • Now you will need to 'unlock' the top and bottom of the base from each other. On the flat edge, there is a rectangle inset with one side cut out. Insert a metal spudger about 1/2'' in to the opening to toggle open an interior tab.
    • With the metal tool still inserted, use an opening tool between the black and silver sides to pry the base open.
  3. Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 3, immagine 1 di 2 Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 3, immagine 2 di 2
    • Once you have the halves opened at least 1/4'', remove the metal key and rotate the base a quarter turn in any direction.
    • Continue using the spudger to pry open the base at each quarter turn until the sides separate easily.
    • The black bottom will catch on the power cord plug, to prevent total dismantlement.
  4. Caribou Coffee CC-EKV8SS7 Power Cord Replacement, Power Cord: passo 4, immagine 1 di 3 Caribou Coffee CC-EKV8SS7 Power Cord Replacement, Power Cord: passo 4, immagine 2 di 3 Caribou Coffee CC-EKV8SS7 Power Cord Replacement, Power Cord: passo 4, immagine 3 di 3
    • Begin detaching the circuit board by removing four rounded top (12mm) Philips head screws (one from each corner).
    • When removing thin metal components, hand protection is recommended to avoid small but painful slices to your fingers.
    • Find the blue and black wires that connect to the circuit board from the power cord. Using moderate force, pull them away from their silver tabs on the circuit board.
  5. Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 5, immagine 1 di 1
    • Detach the power cord's grounding wire (yellow with green stripes) from the edge. First unbend the silver strip, then pull upwards with a small jiggle.
  6. Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 6, immagine 1 di 3 Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 6, immagine 2 di 3 Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 6, immagine 3 di 3
    • Remove the two rounded top (12mm) Phillips Head screws from the 1'' bar holding down the power cord.
  7. Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 7, immagine 1 di 3 Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 7, immagine 2 di 3 Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 7, immagine 3 di 3
    • Disconnect five metal connectors attached to the center circle - three wires from the circuit board, and two wires from the power cord.
    • From the circuit board, there are two white wires and one red wire to be disconnected.
    • From the power cord, there is a green wire, as well as two wires (one blue, one white) connected with black electrical tape near the metal.
  8. Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 8, immagine 1 di 3 Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 8, immagine 2 di 3 Caribou Coffee CC-EKV8SS7 Power Cord Replacement: passo 8, immagine 3 di 3
    • At this point, as long as all the color-coded wires at the end are straightened, the power cord can be pulled through the black base bottom.
    • Discard the old power cord and insert the new power cord by following these instructions in reverse.
Conclusione
Altre 2 persone hanno completato questa guida.
Risa Hess
Membro da: 06/25/17
167 Reputazione
1 Guida realizzata
UW Tacoma, Team S1-G3, Liner Summer 2017 Membro di UW Tacoma, Team S1-G3, Liner Summer 2017
UWT-LINER-SU17S1G3
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 310
