Salta al contenuto principale
Carburetor Disassembly
Cosa ti serve
  1. Carburetor Disassembly, Remove air filter + housing: passo 1, immagine 1 di 3 Carburetor Disassembly, Remove air filter + housing: passo 1, immagine 2 di 3 Carburetor Disassembly, Remove air filter + housing: passo 1, immagine 3 di 3
    • Use a 5/16 socket or flat head screwdriver to remove the first bolt. Pull the cover off and remove the air filter.
    • Remove the 3 bolts using a 5/16 socket. In addition, pull the breather hose off the assembly at the bottom left. Now pull the cover off.
  2. Carburetor Disassembly, Remove carburetor: passo 2, immagine 1 di 3 Carburetor Disassembly, Remove carburetor: passo 2, immagine 2 di 3 Carburetor Disassembly, Remove carburetor: passo 2, immagine 3 di 3
    • Remove the two bolts holding the carburetor to the engine with a 3/8 socket or wrench.
    • Remove the spring boxed in red from the hole. Pull to left of carburetor, towards the link the other end of the spring is around.
    • The link will be connected to the carburetor. Pull the carburetor off in an "S" motion and remove it.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 40
Tutti i Tempi: 1,526
