Salta al contenuto principale
Carburetor Cleaning
Cosa ti serve
  1. Carburetor Cleaning, Air Filter: passo 1, immagine 1 di 3 Carburetor Cleaning, Air Filter: passo 1, immagine 2 di 3 Carburetor Cleaning, Air Filter: passo 1, immagine 3 di 3
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. Carburetor Cleaning: passo 2, immagine 1 di 1
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
  3. Carburetor Cleaning, Carburetor Cleaning: passo 3, immagine 1 di 3 Carburetor Cleaning, Carburetor Cleaning: passo 3, immagine 2 di 3 Carburetor Cleaning, Carburetor Cleaning: passo 3, immagine 3 di 3
    • Locate the four bolts holding the air filter housing to the engine. Remove these bolts using the ratchet driver and the appropriately sized socket.
    • Remove the 1/4" bolts.
    • Remove the 5/16" bolts.
  4. Carburetor Cleaning: passo 4, immagine 1 di 2 Carburetor Cleaning: passo 4, immagine 2 di 2
    • Lift away the air filter housing.
    • Note that the housing is still attached to the engine via a bendable plastic rod.
  5. Carburetor Cleaning: passo 5, immagine 1 di 1
    • Spray carburetor cleaner into the open carburetor.
    • You may want to wear gloves for this step, as carburetor cleaner is harmful if applied to the skin.
Conclusione
Altre 2 persone hanno completato questa guida.
Ethan Narad
Membro da: 04/19/18
529 Reputazione
3 Guide realizzate
Cal Poly, Team S25-G15, Maness Spring 2018 Membro di Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,572
