Salta al contenuto principale
Car Seat Belt Stopper Replacement
Cosa ti serve
    1. Car Seat Belt Stopper Replacement, Car Seat Belt Stopper: passo 1, immagine 1 di 1
      • Use a cloth to wipe away any debris from the area.
      Chiedi a FixBot
      Aggiungi Commento
    2. Car Seat Belt Stopper Replacement: passo 2, immagine 1 di 1
      • Find the existing hole for the seat belt stopper or choose a different location that is better for you.
      • Separate the replacement stopper if it has come assembled.
      Chiedi a FixBot
      Aggiungi Commento
    3. Car Seat Belt Stopper Replacement: passo 3, immagine 1 di 1
      • Before you begin, make sure that the seat belt buckle is pushed above the hole where you are installing the new seat belt stopper.
      • Push the side of the seat belt button with the needle or point into your desired location.
      • It may require a small amount of force.
      Chiedi a FixBot
      Aggiungi Commento
    4. Car Seat Belt Stopper Replacement: passo 4, immagine 1 di 1
      • Take the other half of button stopper and slide it onto the pin on the other side of the belt.
      • Fasten the two parts of the button together and squeeze for a secure fit.
      • You may hear a "snap" or "click" when they are fastened together.
      Chiedi a FixBot
      Aggiungi Commento
    5. Car Seat Belt Stopper Replacement: passo 5, immagine 1 di 1
      • Check the position of the replacement stopper for a comfortable fit.
      Chiedi a FixBot
      Aggiungi Commento
    6. Car Seat Belt Stopper Replacement: passo 6, immagine 1 di 1
      • Now you can use the seat belt buckle without it falling down!
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Changing your positioning of replacement can be used to your liking.
Zhong Chu
Membro da: 04/23/24
137 Reputazione
Una guida realizzata
UC Davis, Team 4-1, Whithaus Spring 2024 Membro di UC Davis, Team 4-1, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G1
3 Membri
8 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 40
Ultimi 30 giorni: 171
Tutti i Tempi: 3,256
