Salta al contenuto principale
Capresso Perfectea 260 Motherboard Replacement
Cosa ti serve
  1. Capresso Perfectea 260 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • First, take the base of the device and flip it over.
  2. Capresso Perfectea 260 Motherboard Replacement: passo 2, immagine 1 di 2 Capresso Perfectea 260 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso Perfectea 260 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso Perfectea 260 Motherboard Replacement: passo 4, immagine 1 di 1
    • Unplug the wire going into the side of the motherboard
  5. Capresso Perfectea 260 Motherboard Replacement: passo 5, immagine 1 di 2 Capresso Perfectea 260 Motherboard Replacement: passo 5, immagine 2 di 2
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso Perfectea 260 Motherboard Replacement: passo 6, immagine 1 di 1
    • Lift the motherboard out of the device
Conclusione
Cal Poly, Team 6-17, Maness Spring 2015 Membro di Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 235
