Cosa ti serve
Lift the lid of the Perfectea
Remove the two 12mm Phillips #2 screws located at the brim of the pot.
Firmly grip the glass pot with one hand while using the other to slip the flat end of the plastic opening tool between the glass pot and the adhesive tape holding the handle to the glass pot.
Gently pry the adhesive tape from the glass pot. Work your way around the handle until the handle is loose and not attached to the pot anymore.
The bottom panel has four wires that latch on to four tabs.
Use the metal spudger to pry up one metal tab in the latch.
Apply pressure with the metal spudger to the other tab on the latch to slide off tab.
Repeat for the remaining three tabs.
The bottom panel should now be disconnected from the rest of the kettle.
Altre 3 persone hanno completato questa guida.
2 Commenti
This guide applies almost identically to the Capresso H2O kettle, which doesn't have the control board. Thanks for the guide.
