Introduzione
If you have a broken or loose dial, then this guide can help you replace it.
Cosa ti serve
Remove the two 7.5mm Phillips #2 screws from the metal frame.
Remove the frame from the assembly.
Find the cable that attaches the small computer chip to the heating element connections.
Use the spudger to cut open the rubber coating on the latch where it clamps onto the copper tab.
Insert the metal spudger into the rectangular hole on the latch and push toward the tab (away from the wire) to unbend the tab.
Push the latch off the tab with the spudger.
Remove the two 6 mm Phillips #1 screws from the black dial base plate.
Remove the black dial base plate, metal spring, LED tube, and the actual dial.
