Salta al contenuto principale
Canon ZR70MC Speaker Replacement
Cosa ti serve
  1. Canon ZR70MC Speaker Replacement, Front Panel: passo 1, immagine 1 di 2 Canon ZR70MC Speaker Replacement, Front Panel: passo 1, immagine 2 di 2
    • Unscrew the 3.35mm screw.
  2. Canon ZR70MC Speaker Replacement: passo 2, immagine 1 di 1
    • Turn the ZR70MC so that you can see the bottom of the camcorder.
    • Unscrew the 3.35 mm located in the top left portion of the camera.
  3. Canon ZR70MC Speaker Replacement: passo 3, immagine 1 di 3 Canon ZR70MC Speaker Replacement: passo 3, immagine 2 di 3 Canon ZR70MC Speaker Replacement: passo 3, immagine 3 di 3
    • Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
    • Remove the 2.65 mm screw.
  4. Canon ZR70MC Speaker Replacement: passo 4, immagine 1 di 3 Canon ZR70MC Speaker Replacement: passo 4, immagine 2 di 3 Canon ZR70MC Speaker Replacement: passo 4, immagine 3 di 3
    • Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
    • Locate and remove the two 3.35 mm screws.
  5. Canon ZR70MC Speaker Replacement: passo 5, immagine 1 di 2 Canon ZR70MC Speaker Replacement: passo 5, immagine 2 di 2
    • Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
    • There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
  6. Canon ZR70MC Speaker Replacement: passo 6, immagine 1 di 3 Canon ZR70MC Speaker Replacement: passo 6, immagine 2 di 3 Canon ZR70MC Speaker Replacement: passo 6, immagine 3 di 3
    • Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
    • The speaker will be connected to the main body by a wire. Be careful not to damage this wire.
  7. Canon ZR70MC Speaker Replacement: passo 7, immagine 1 di 3 Canon ZR70MC Speaker Replacement: passo 7, immagine 2 di 3 Canon ZR70MC Speaker Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to gently pull the speaker wire from the main body of the camcorder.
    • Pull the front panel completely away from the main body of the camcorder.
  8. Canon ZR70MC Speaker Replacement, Speaker: passo 8, immagine 1 di 3 Canon ZR70MC Speaker Replacement, Speaker: passo 8, immagine 2 di 3 Canon ZR70MC Speaker Replacement, Speaker: passo 8, immagine 3 di 3
    • Take the front panel and remove the three 2.75 mm screws from the metal plate.
  9. Canon ZR70MC Speaker Replacement: passo 9, immagine 1 di 3 Canon ZR70MC Speaker Replacement: passo 9, immagine 2 di 3 Canon ZR70MC Speaker Replacement: passo 9, immagine 3 di 3
    • Remove the metal plate. This metal plate protects the black speaker holder.
  10. Canon ZR70MC Speaker Replacement: passo 10, immagine 1 di 3 Canon ZR70MC Speaker Replacement: passo 10, immagine 2 di 3 Canon ZR70MC Speaker Replacement: passo 10, immagine 3 di 3
    • Remove the black speaker holder from the front panel. This holds the individual speakers.
  11. Canon ZR70MC Speaker Replacement: passo 11, immagine 1 di 3 Canon ZR70MC Speaker Replacement: passo 11, immagine 2 di 3 Canon ZR70MC Speaker Replacement: passo 11, immagine 3 di 3
    • Remove the individual speakers from the black speaker holder.
Conclusione
USF Tampa, Team S13-G2, Boczar Fall 2017 Membro di USF Tampa, Team S13-G2, Boczar Fall 2017
USFT-BOCZAR-F17S13G2
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 138
