Salta al contenuto principale
Canon ZR70MC Side Panel Replacement
Cosa ti serve
  1. Canon ZR70MC Side Panel Replacement, Front Panel: passo 1, immagine 1 di 2 Canon ZR70MC Side Panel Replacement, Front Panel: passo 1, immagine 2 di 2
    • Unscrew the 3.35mm screw.
  2. Canon ZR70MC Side Panel Replacement: passo 2, immagine 1 di 1
    • Turn the ZR70MC so that you can see the bottom of the camcorder.
    • Unscrew the 3.35 mm located in the top left portion of the camera.
  3. Canon ZR70MC Side Panel Replacement: passo 3, immagine 1 di 3 Canon ZR70MC Side Panel Replacement: passo 3, immagine 2 di 3 Canon ZR70MC Side Panel Replacement: passo 3, immagine 3 di 3
    • Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
    • Remove the 2.65 mm screw.
  4. Canon ZR70MC Side Panel Replacement: passo 4, immagine 1 di 3 Canon ZR70MC Side Panel Replacement: passo 4, immagine 2 di 3 Canon ZR70MC Side Panel Replacement: passo 4, immagine 3 di 3
    • Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
    • Locate and remove the two 3.35 mm screws.
  5. Canon ZR70MC Side Panel Replacement: passo 5, immagine 1 di 2 Canon ZR70MC Side Panel Replacement: passo 5, immagine 2 di 2
    • Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
    • There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
  6. Canon ZR70MC Side Panel Replacement: passo 6, immagine 1 di 3 Canon ZR70MC Side Panel Replacement: passo 6, immagine 2 di 3 Canon ZR70MC Side Panel Replacement: passo 6, immagine 3 di 3
    • Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
    • The speaker will be connected to the main body by a wire. Be careful not to damage this wire.
  7. Canon ZR70MC Side Panel Replacement: passo 7, immagine 1 di 3 Canon ZR70MC Side Panel Replacement: passo 7, immagine 2 di 3 Canon ZR70MC Side Panel Replacement: passo 7, immagine 3 di 3
    • Use tweezers to gently pull the speaker wire from the main body of the camcorder.
    • Pull the front panel completely away from the main body of the camcorder.
  8. Canon ZR70MC Side Panel Replacement, Side Panel: passo 8, immagine 1 di 1
    • Remove all 3.75 mm screws from the bottom of the camcorder.
  9. Canon ZR70MC Side Panel Replacement: passo 9, immagine 1 di 2 Canon ZR70MC Side Panel Replacement: passo 9, immagine 2 di 2
    • Turn the camcorder so that the back is facing you.
    • Remove the 3.75 mm screws from the back of the camcorder that hold the side panel in place.
  10. Canon ZR70MC Side Panel Replacement: passo 10, immagine 1 di 2 Canon ZR70MC Side Panel Replacement: passo 10, immagine 2 di 2
    • Now that all of the screws are removed, gently pull off the side panel of the camcorder.
  11. Canon ZR70MC Side Panel Replacement: passo 11, immagine 1 di 2 Canon ZR70MC Side Panel Replacement: passo 11, immagine 2 di 2
    • Gently pull the two black wires from their connections. These black wires are the only thing left connecting the side panel to the main body of the camcorder.
  12. Canon ZR70MC Side Panel Replacement: passo 12, immagine 1 di 1
    • Gently pull the orange films out of their connections. This will allow you access to all components of the main body.
Conclusione
USF Tampa, Team S13-G2, Boczar Fall 2017 Membro di USF Tampa, Team S13-G2, Boczar Fall 2017
USFT-BOCZAR-F17S13G2
3 Membri
14 Guide realizzate
Un commento
How to fix the start/stop button when it doesn't responding.
Cedee Nunnil Gampal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 301
