Salta al contenuto principale
Canon Vixia HF20 Camcorder Strap Replacement
  1. Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: passo 1, immagine 1 di 3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: passo 1, immagine 2 di 3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: passo 1, immagine 3 di 3
    • Un-velcro the camcorder strap.
    • Remove the strap from the first hole by pulling towards the front of the camcorder, continue pulling the strap through until it is removed from second anchor point as well.
    • There should now be two empty anchor points.
  2. Canon Vixia HF20 Camcorder Strap Replacement: passo 2, immagine 1 di 3 Canon Vixia HF20 Camcorder Strap Replacement: passo 2, immagine 2 di 3 Canon Vixia HF20 Camcorder Strap Replacement: passo 2, immagine 3 di 3
    • Re-insert the new Velcro strap through the back anchor hole in the direction of the arrow (toward the battery end of the camcorder).
    • Then through the padded hand strap in direction of the arrow.
    • Lastly, pull the strap through the front anchor hole adjusting for your grip.
  3. Canon Vixia HF20 Camcorder Strap Replacement: passo 3, immagine 1 di 1
    • Once the fit is adjusted, secure by closing the padded strap.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 516
