Salta al contenuto principale
Canon Vixia HF S10 Camcorder Audio Replacement
Cosa ti serve
  1. Canon Vixia HF S10 Camcorder Audio Replacement, Audio: passo 1, immagine 1 di 3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: passo 1, immagine 2 di 3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: passo 1, immagine 3 di 3
    • Turn the camcorder upside down and remove the three 3x4 mm Phillips screws securing the black plastic case.
    • Flip open the LCD screen.
    • Remove the three 3x4 mm Phillips screws securing the black panel plastic case.
  2. Canon Vixia HF S10 Camcorder Audio Replacement: passo 2, immagine 1 di 3 Canon Vixia HF S10 Camcorder Audio Replacement: passo 2, immagine 2 di 3 Canon Vixia HF S10 Camcorder Audio Replacement: passo 2, immagine 3 di 3
    • From the inner corner in between the panel and the LCD screen, remove the two 2x2.5 mm Phillips screws and the 3x4 mm Phillips screw.
    • Remove the black plastic covering with your fingers. Underneath the covering, you will find a screw hinge.
    • Remove the 2x2.25 mm Phillips screw located at the top of the screw hinge.
  3. Canon Vixia HF S10 Camcorder Audio Replacement: passo 3, immagine 1 di 3 Canon Vixia HF S10 Camcorder Audio Replacement: passo 3, immagine 2 di 3 Canon Vixia HF S10 Camcorder Audio Replacement: passo 3, immagine 3 di 3
    • Using your fingers, remove the panel from the base of the camcorder.
    • After removing the panel, remove the two 2x2.25 mm Phillips screws located at the top right of the inside of the panel.
    • Using one hand, gently move the silver piece holding the speaker down while using the other hand to remove the speaker.
Conclusione
Clint
Membro da: 03/03/15
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 420
