Introduzione
The top panel is the glossy plastic piece that rests on the top of the camcorder and protects the inner components. Along with the side panel, it must be removed before the internal parts of the camcorder can be accessed. Use this guide to remove and replace the top panel to your Canon Vixia HF R70.
Cosa ti serve
Power off and unplug the device.
Position the camera so that the battery is facing you.
Position the camcorder so that the wrist strap is facing you.
Locate the loose end of the strap.
Position the camcorder so that the side panel is facing you.
Locate the two 6mm Phillips #00 screws on the side panel.
Remove the the screws using a screwdriver with a Phillips #00 head.
Disconnect the wires by inserting the plastic opening tool into the small slit.
Begin to push upward with the plastic opening tool, disconnecting the two compartments.
