Salta al contenuto principale
Canon Vixia HF R70 Side Panel Replacement
Cosa ti serve
  1. Canon Vixia HF R70 Side Panel Replacement, Battery: passo 1, immagine 1 di 1
    • Power off and unplug the device.
    • Position the camera so that the battery is facing you.
  2. Canon Vixia HF R70 Side Panel Replacement: passo 2, immagine 1 di 1
    • Locate the latch on the bottom edge of the camera.
    • Hold the battery into place and gently push down on the latch towards the lens.
  3. Canon Vixia HF R70 Side Panel Replacement: passo 3, immagine 1 di 2 Canon Vixia HF R70 Side Panel Replacement: passo 3, immagine 2 di 2
    • While holding down the latch, remove the battery by pulling it out of the device.
  4. Canon Vixia HF R70 Side Panel Replacement, Wrist Strap: passo 4, immagine 1 di 1
    • Position the camcorder so that the wrist strap is facing you.
    • Locate the loose end of the strap.
  5. Canon Vixia HF R70 Side Panel Replacement: passo 5, immagine 1 di 1
    • Gently pull on the loose end to separate the Velcro.
  6. Canon Vixia HF R70 Side Panel Replacement: passo 6, immagine 1 di 1
    • Locate the "slot" on bottom right corner of the camcorder where the strap loops through.
    • Pull the strap through the loop.
  7. Canon Vixia HF R70 Side Panel Replacement: passo 7, immagine 1 di 2 Canon Vixia HF R70 Side Panel Replacement: passo 7, immagine 2 di 2
    • Pull the strap through the leather cushion.
  8. Canon Vixia HF R70 Side Panel Replacement: passo 8, immagine 1 di 1
    • Pull the strap through the slot on the left side of the camcorder.
  9. Canon Vixia HF R70 Side Panel Replacement, Side Panel: passo 9, immagine 1 di 2 Canon Vixia HF R70 Side Panel Replacement, Side Panel: passo 9, immagine 2 di 2
    • Position the camcorder so that the side panel is facing you.
    • Locate the two 6mm Phillips #00 screws on the side panel.
    • Remove the the screws using a screwdriver with a Phillips #00 head.
  10. Canon Vixia HF R70 Side Panel Replacement: passo 10, immagine 1 di 3 Canon Vixia HF R70 Side Panel Replacement: passo 10, immagine 2 di 3 Canon Vixia HF R70 Side Panel Replacement: passo 10, immagine 3 di 3
    • Turn the camcorder so that the bottom is facing you.
    • Using your screwdriver, locate and remove the four 6mm Phillips #00 screws connecting the side panel to the bottom of the camcorder.
  11. Canon Vixia HF R70 Side Panel Replacement: passo 11, immagine 1 di 2 Canon Vixia HF R70 Side Panel Replacement: passo 11, immagine 2 di 2
    • Gently remove the side panel by pushing it up from the bottom.
Conclusione
USF Tampa, Team S2-G2, Nance Spring 2017 Membro di USF Tampa, Team S2-G2, Nance Spring 2017
USFT-NANCE-S17S2G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 418
