Salta al contenuto principale
Canon Vixia HF R70 SD Card Replacement
  1. Canon Vixia HF R70 SD Card Replacement, SD Card: passo 1, immagine 1 di 3 Canon Vixia HF R70 SD Card Replacement, SD Card: passo 1, immagine 2 di 3 Canon Vixia HF R70 SD Card Replacement, SD Card: passo 1, immagine 3 di 3
    • Open the screen compartment.
    • Position the camcorder so that the screen is facing you.
  2. Canon Vixia HF R70 SD Card Replacement: passo 2, immagine 1 di 2 Canon Vixia HF R70 SD Card Replacement: passo 2, immagine 2 di 2
    • Find the SD card compartment.
    • Place your finger under the slot and gently slide it forward to open the compartment.
  3. Canon Vixia HF R70 SD Card Replacement: passo 3, immagine 1 di 2 Canon Vixia HF R70 SD Card Replacement: passo 3, immagine 2 di 2
    • Gently push on the SD card until you hear a "click". The SD card should pop out.
    • Remove the old SD card by pulling it out.
Conclusione
USF Tampa, Team S2-G2, Nance Spring 2017 Membro di USF Tampa, Team S2-G2, Nance Spring 2017
USFT-NANCE-S17S2G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 237
