Introduzione
In this guide I will be demonstrating how to properly replace the navigation button on the top of the camera. The common signs of a broken or failing navigation button are if the button fails to move or is jammed, when moved the button doesn’t do anything, the button when moved produces a delayed response, if any of these symptoms appear it is likely that this is the primary issue with the device.
Cosa ti serve
Remove the strap by undoing the Velcro and pulling it through the thread points.
Remove the external battery pack by pressing down on the slide release and sliding it out.
Use the Phillips #000 screwdriver to remove three 3mm Phillips #000 screws from the outer casing shell around the record button and remove it and the small microchip.
