Salta al contenuto principale
Canon Vixia HF R62 Navigation Buttons Replacement
Cosa ti serve
  1. Canon Vixia HF R62 Navigation Buttons Replacement, Outer Shell: passo 1, immagine 1 di 2 Canon Vixia HF R62 Navigation Buttons Replacement, Outer Shell: passo 1, immagine 2 di 2
    • Remove the strap by undoing the Velcro and pulling it through the thread points.
    • Remove the external battery pack by pressing down on the slide release and sliding it out.
  2. Canon Vixia HF R62 Navigation Buttons Replacement: passo 2, immagine 1 di 2 Canon Vixia HF R62 Navigation Buttons Replacement: passo 2, immagine 2 di 2
    • Remove the three 5mm Phillips #000 screws on the bottom of the device.
  3. Canon Vixia HF R62 Navigation Buttons Replacement: passo 3, immagine 1 di 2 Canon Vixia HF R62 Navigation Buttons Replacement: passo 3, immagine 2 di 2
    • On the side of the device, remove the following Phillips #000 screws:
    • One 3mm screw
    • One 5mm screw
  4. Canon Vixia HF R62 Navigation Buttons Replacement: passo 4, immagine 1 di 2 Canon Vixia HF R62 Navigation Buttons Replacement: passo 4, immagine 2 di 2
    • Remove the panel opposite the display by pulling up perpendicular to the side.
  5. Canon Vixia HF R62 Navigation Buttons Replacement: passo 5, immagine 1 di 1
    • Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
  6. Canon Vixia HF R62 Navigation Buttons Replacement: passo 6, immagine 1 di 2 Canon Vixia HF R62 Navigation Buttons Replacement: passo 6, immagine 2 di 2
    • Remove the three 4mm Phillips #000 screws shown.
    • There will be foam covers protecting some or all of these screws. These will need to be removed before you will be able to unscrew them.
  7. Canon Vixia HF R62 Navigation Buttons Replacement: passo 7, immagine 1 di 3 Canon Vixia HF R62 Navigation Buttons Replacement: passo 7, immagine 2 di 3 Canon Vixia HF R62 Navigation Buttons Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, disconnect this ribbon cable by pulling straight out.
  8. Canon Vixia HF R62 Navigation Buttons Replacement: passo 8, immagine 1 di 3 Canon Vixia HF R62 Navigation Buttons Replacement: passo 8, immagine 2 di 3 Canon Vixia HF R62 Navigation Buttons Replacement: passo 8, immagine 3 di 3
    • Repeat step seven (7) for the remaining three wires shown.
  9. Canon Vixia HF R62 Navigation Buttons Replacement: passo 9, immagine 1 di 3 Canon Vixia HF R62 Navigation Buttons Replacement: passo 9, immagine 2 di 3 Canon Vixia HF R62 Navigation Buttons Replacement: passo 9, immagine 3 di 3
    • Grasp the top of the camera and pull straight up to remove the top panel.
  10. Canon Vixia HF R62 Navigation Buttons Replacement, Navigation Buttons: passo 10, immagine 1 di 3 Canon Vixia HF R62 Navigation Buttons Replacement, Navigation Buttons: passo 10, immagine 2 di 3 Canon Vixia HF R62 Navigation Buttons Replacement, Navigation Buttons: passo 10, immagine 3 di 3
    • Use the Phillips #000 screwdriver to remove three 3mm Phillips #000 screws from the outer casing shell around the record button and remove it and the small microchip.
  11. Canon Vixia HF R62 Navigation Buttons Replacement: passo 11, immagine 1 di 3 Canon Vixia HF R62 Navigation Buttons Replacement: passo 11, immagine 2 di 3 Canon Vixia HF R62 Navigation Buttons Replacement: passo 11, immagine 3 di 3
    • Use the Phillips #000 screwdriver to remove five 3mm Phillips #000 screws from the outer casing shell and remove the metal piece containing the speaker.
  12. Canon Vixia HF R62 Navigation Buttons Replacement: passo 12, immagine 1 di 3 Canon Vixia HF R62 Navigation Buttons Replacement: passo 12, immagine 2 di 3 Canon Vixia HF R62 Navigation Buttons Replacement: passo 12, immagine 3 di 3
    • Remove one 3mm Phillips #000 screw holding the navigation button in. Then use the metal spudger to separate the button from the casing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 112
