Salta al contenuto principale
Canon Vixia HF R62 Microphone Replacement
Cosa ti serve
  1. Canon Vixia HF R62 Microphone Replacement, Outer Shell: passo 1, immagine 1 di 2 Canon Vixia HF R62 Microphone Replacement, Outer Shell: passo 1, immagine 2 di 2
    • Remove the strap by undoing the Velcro and pulling it through the thread points.
    • Remove the external battery pack by pressing down on the slide release and sliding it out.
  2. Canon Vixia HF R62 Microphone Replacement: passo 2, immagine 1 di 2 Canon Vixia HF R62 Microphone Replacement: passo 2, immagine 2 di 2
    • Remove the three 5mm Phillips #000 screws on the bottom of the device.
  3. Canon Vixia HF R62 Microphone Replacement: passo 3, immagine 1 di 2 Canon Vixia HF R62 Microphone Replacement: passo 3, immagine 2 di 2
    • On the side of the device, remove the following Phillips #000 screws:
    • One 3mm screw
    • One 5mm screw
  4. Canon Vixia HF R62 Microphone Replacement: passo 4, immagine 1 di 2 Canon Vixia HF R62 Microphone Replacement: passo 4, immagine 2 di 2
    • Remove the panel opposite the display by pulling up perpendicular to the side.
  5. Canon Vixia HF R62 Microphone Replacement: passo 5, immagine 1 di 1
    • Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
  6. Canon Vixia HF R62 Microphone Replacement: passo 6, immagine 1 di 2 Canon Vixia HF R62 Microphone Replacement: passo 6, immagine 2 di 2
    • Remove the three 4mm Phillips #000 screws shown.
    • There will be foam covers protecting some or all of these screws. These will need to be removed before you will be able to unscrew them.
  7. Canon Vixia HF R62 Microphone Replacement: passo 7, immagine 1 di 3 Canon Vixia HF R62 Microphone Replacement: passo 7, immagine 2 di 3 Canon Vixia HF R62 Microphone Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, disconnect this ribbon cable by pulling straight out.
  8. Canon Vixia HF R62 Microphone Replacement: passo 8, immagine 1 di 3 Canon Vixia HF R62 Microphone Replacement: passo 8, immagine 2 di 3 Canon Vixia HF R62 Microphone Replacement: passo 8, immagine 3 di 3
    • Repeat step seven (7) for the remaining three wires shown.
  9. Canon Vixia HF R62 Microphone Replacement: passo 9, immagine 1 di 3 Canon Vixia HF R62 Microphone Replacement: passo 9, immagine 2 di 3 Canon Vixia HF R62 Microphone Replacement: passo 9, immagine 3 di 3
    • Grasp the top of the camera and pull straight up to remove the top panel.
  10. Canon Vixia HF R62 Microphone Replacement, Microphone: passo 10, immagine 1 di 1
    • Remove the 5mm Phillips #000 screw on top of the inner case.
  11. Canon Vixia HF R62 Microphone Replacement: passo 11, immagine 1 di 2 Canon Vixia HF R62 Microphone Replacement: passo 11, immagine 2 di 2
    • Remove the two 5mm Phillips #000 screws near the display panel.
  12. Canon Vixia HF R62 Microphone Replacement: passo 12, immagine 1 di 2 Canon Vixia HF R62 Microphone Replacement: passo 12, immagine 2 di 2
    • Disconnect the small bundled cable connector on the side of the lens cover by pulling it straight out.
  13. Canon Vixia HF R62 Microphone Replacement: passo 13, immagine 1 di 2 Canon Vixia HF R62 Microphone Replacement: passo 13, immagine 2 di 2
    • Remove the lens cover by pulling straight away from the body.
  14. Canon Vixia HF R62 Microphone Replacement: passo 14, immagine 1 di 1
    • Remove 4mm Phillips #000 from the lens cover.
  15. Canon Vixia HF R62 Microphone Replacement: passo 15, immagine 1 di 1
    • Remove the plastic casing.
  16. Canon Vixia HF R62 Microphone Replacement: passo 16, immagine 1 di 2 Canon Vixia HF R62 Microphone Replacement: passo 16, immagine 2 di 2
    • Pull the microphone apart from the lens cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 149
