Salta al contenuto principale
Canon Vixia HF R62 Display Panel Replacement
Cosa ti serve
  1. Canon Vixia HF R62 Display Panel Replacement, Outer Shell: passo 1, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement, Outer Shell: passo 1, immagine 2 di 2
    • Remove the strap by undoing the Velcro and pulling it through the thread points.
    • Remove the external battery pack by pressing down on the slide release and sliding it out.
  2. Canon Vixia HF R62 Display Panel Replacement: passo 2, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 2, immagine 2 di 2
    • Remove the three 5mm Phillips #000 screws on the bottom of the device.
  3. Canon Vixia HF R62 Display Panel Replacement: passo 3, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 3, immagine 2 di 2
    • On the side of the device, remove the following Phillips #000 screws:
    • One 3mm screw
    • One 5mm screw
  4. Canon Vixia HF R62 Display Panel Replacement: passo 4, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 4, immagine 2 di 2
    • Remove the panel opposite the display by pulling up perpendicular to the side.
  5. Canon Vixia HF R62 Display Panel Replacement: passo 5, immagine 1 di 1
    • Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
  6. Canon Vixia HF R62 Display Panel Replacement: passo 6, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 6, immagine 2 di 2
    • Remove the three 4mm Phillips #000 screws shown.
    • There will be foam covers protecting some or all of these screws. These will need to be removed before you will be able to unscrew them.
  7. Canon Vixia HF R62 Display Panel Replacement: passo 7, immagine 1 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 7, immagine 2 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, disconnect this ribbon cable by pulling straight out.
  8. Canon Vixia HF R62 Display Panel Replacement: passo 8, immagine 1 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 8, immagine 2 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 8, immagine 3 di 3
    • Repeat step seven (7) for the remaining three wires shown.
  9. Canon Vixia HF R62 Display Panel Replacement: passo 9, immagine 1 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 9, immagine 2 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 9, immagine 3 di 3
    • Grasp the top of the camera and pull straight up to remove the top panel.
  10. Canon Vixia HF R62 Display Panel Replacement, Lens: passo 10, immagine 1 di 1
    • Remove the 5mm Phillips #000 screw on top of the inner case.
  11. Canon Vixia HF R62 Display Panel Replacement: passo 11, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 11, immagine 2 di 2
    • Remove the two 5mm Phillips #000 screws near the display panel.
  12. Canon Vixia HF R62 Display Panel Replacement: passo 12, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 12, immagine 2 di 2
    • Disconnect the small bundled cable connector on the side of the lens cover by pulling it straight out.
  13. Canon Vixia HF R62 Display Panel Replacement: passo 13, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 13, immagine 2 di 2
    • Remove the lens cover by pulling straight away from the body.
  14. Canon Vixia HF R62 Display Panel Replacement: passo 14, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 14, immagine 2 di 2
    • Remove the three 6mm Phillips #000 screws shown.
  15. Canon Vixia HF R62 Display Panel Replacement: passo 15, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 15, immagine 2 di 2
    • Remove the lens by pulling straight away from the main body.
    • Be aware of the small rubber gasket around the lens as it may come loose.
  16. Canon Vixia HF R62 Display Panel Replacement, Internal Battery and SD Card Reader: passo 16, immagine 1 di 3 Canon Vixia HF R62 Display Panel Replacement, Internal Battery and SD Card Reader: passo 16, immagine 2 di 3 Canon Vixia HF R62 Display Panel Replacement, Internal Battery and SD Card Reader: passo 16, immagine 3 di 3
    • Remove the two 3mm Phillips #000 screws.
    • Remove the 4mm Phillips #000 screw.
  17. Canon Vixia HF R62 Display Panel Replacement: passo 17, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 17, immagine 2 di 2
    • Disconnect the ribbon cable shown.
  18. Canon Vixia HF R62 Display Panel Replacement: passo 18, immagine 1 di 1
    • Remove the 4mm Phillips #000 screw at the bottom of the camera.
  19. Canon Vixia HF R62 Display Panel Replacement: passo 19, immagine 1 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 19, immagine 2 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 19, immagine 3 di 3
    • Place the spudger under the tab shown.
    • While prying the tab up with the spudger, pull the case away.
  20. Canon Vixia HF R62 Display Panel Replacement, Central Capturing Unit: passo 20, immagine 1 di 3 Canon Vixia HF R62 Display Panel Replacement, Central Capturing Unit: passo 20, immagine 2 di 3 Canon Vixia HF R62 Display Panel Replacement, Central Capturing Unit: passo 20, immagine 3 di 3
    • Using a spudger, disconnect the ribbon cable connector from the PC board shown in the picture.
  21. Canon Vixia HF R62 Display Panel Replacement: passo 21, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 21, immagine 2 di 2
    Compra
    • Using tweezers, disconnect the ribbon cable shown in the picture by pulling straight out.
  22. Canon Vixia HF R62 Display Panel Replacement: passo 22, immagine 1 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 22, immagine 2 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 22, immagine 3 di 3
    • Using a spudger, gently pry up the top tab on the ZIF connector. The wire will now disconnect with no force needed.
    • When reassembling you will need to place the ribbon wire tightly against the tab in order to properly secure it.
  23. Canon Vixia HF R62 Display Panel Replacement: passo 23, immagine 1 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 23, immagine 2 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 23, immagine 3 di 3
    • Using your fingers, firmly grasp both ends of the capturing device and gently pull the assembly straight out.
  24. Canon Vixia HF R62 Display Panel Replacement, Display Panel: passo 24, immagine 1 di 1
    • Remove the 3mm Phillips #000 screw holding the display's ribbon wire to the casing.
  25. Canon Vixia HF R62 Display Panel Replacement: passo 25, immagine 1 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 25, immagine 2 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 25, immagine 3 di 3
    • Undo the ZIF connector from the motherboard using a plastic spudger. Use the spudger to pry the small tab on top of the ZIF connector and the ribbon cable will fall free.
    • When reassembling, you will need to place the ribbon cable tightly against the tab in order to properly secure it.
  26. Canon Vixia HF R62 Display Panel Replacement: passo 26, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 26, immagine 2 di 2
    Compra
    • There is a small component of the ribbon cable clipped to the casing. Remove this by pulling it away from the casing with tweezers.
    • Some of the ribbon may become entangled in the clips that held the component. Ensure they are untangled before the display is removed to avoid damage.
  27. Canon Vixia HF R62 Display Panel Replacement: passo 27, immagine 1 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 27, immagine 2 di 3 Canon Vixia HF R62 Display Panel Replacement: passo 27, immagine 3 di 3
    • The ribbon cable is also looped around a piece of the casing under the motherboard. Unfasten this cable with tweezers by sliding down and then pulling out.
  28. Canon Vixia HF R62 Display Panel Replacement: passo 28, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 28, immagine 2 di 2
    • Open the display panel.
    • This will help during the reassembly as one of the hinges locks in place and is difficult to reassemble if in the closed position.
  29. Canon Vixia HF R62 Display Panel Replacement: passo 29, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 29, immagine 2 di 2
    • Remove the two 3mm Phillips #000 screws connecting to the display panel's hinges.
  30. Canon Vixia HF R62 Display Panel Replacement: passo 30, immagine 1 di 2 Canon Vixia HF R62 Display Panel Replacement: passo 30, immagine 2 di 2
    • Remove the display panel by pulling the display straight away from the body.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 290
