Introduzione
If your camera's audio is low quality during playback, the speaker assembly may need replacing. This guide will help you remove this assembly; you may need to contact the manufacturer for a replacement part.
Cosa ti serve
Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
To remove the hand-strap, pull the Velcro strip through the leather pad.
Press in the battery release tab located on the bottom of the camera.
Slide the battery out from the body.
Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
Remove one 4mm Phillips JIS#00 screw on the right side of the camera.
Use the plastic opening tool to undo the bronze ribbon connector.
