Salta al contenuto principale
Canon Vixia HF R600 Microphone Replacement
Cosa ti serve
  1. Canon Vixia HF R600 Microphone Replacement, Handstrap: passo 1, immagine 1 di 2 Canon Vixia HF R600 Microphone Replacement, Handstrap: passo 1, immagine 2 di 2
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Microphone Replacement: passo 2, immagine 1 di 2 Canon Vixia HF R600 Microphone Replacement: passo 2, immagine 2 di 2
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Microphone Replacement, Battery: passo 3, immagine 1 di 2 Canon Vixia HF R600 Microphone Replacement, Battery: passo 3, immagine 2 di 2
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Microphone Replacement, Casing: passo 4, immagine 1 di 2 Canon Vixia HF R600 Microphone Replacement, Casing: passo 4, immagine 2 di 2
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 Microphone Replacement: passo 5, immagine 1 di 2 Canon Vixia HF R600 Microphone Replacement: passo 5, immagine 2 di 2
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Microphone Replacement: passo 6, immagine 1 di 2 Canon Vixia HF R600 Microphone Replacement: passo 6, immagine 2 di 2
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 Microphone Replacement, Microphone: passo 7, immagine 1 di 3 Canon Vixia HF R600 Microphone Replacement, Microphone: passo 7, immagine 2 di 3 Canon Vixia HF R600 Microphone Replacement, Microphone: passo 7, immagine 3 di 3
    • Remove one 5mm Phillips PH#00 screw from the top of the camera.
    • Pull away the plastic shutter casing; this contains the microphone.
    • Using the plastic opening tool or something similar, carefully disconnect the white 4 pin connector to remove the shutter casing.
  8. Canon Vixia HF R600 Microphone Replacement: passo 8, immagine 1 di 2 Canon Vixia HF R600 Microphone Replacement: passo 8, immagine 2 di 2
    • Remove the one 4mm Phillips JIS#00 screw from the top of the shutter housing.
    • Pull the shutter away to reveal the metal plate covering the speakers.
  9. Canon Vixia HF R600 Microphone Replacement: passo 9, immagine 1 di 3 Canon Vixia HF R600 Microphone Replacement: passo 9, immagine 2 di 3 Canon Vixia HF R600 Microphone Replacement: passo 9, immagine 3 di 3
    • Remove the one 4mm Phillips JIS#00 from the plastic shutter housing.
    • Pull the metal bracket out of the housing.
    • Carefully remove the speakers from the housing as they contain very thin wires.
Conclusione
Brian Luna
Membro da: 02/10/16
483 Reputazione
4 Guide realizzate
USF Tampa, Team 14-4, Lacy Spring 2016 Membro di USF Tampa, Team 14-4, Lacy Spring 2016
USFT-LACY-S16S14G4
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 293
