Salta al contenuto principale
Canon Vixia HF R500 Disassembly
Cosa ti serve
  1. Canon Vixia HF R500 Disassembly, Canon Vixia HF R500 Disassembly: passo 1, immagine 1 di 2 Canon Vixia HF R500 Disassembly, Canon Vixia HF R500 Disassembly: passo 1, immagine 2 di 2
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  2. Canon Vixia HF R500 Disassembly: passo 2, immagine 1 di 1
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  3. Canon Vixia HF R500 Disassembly: passo 3, immagine 1 di 1
    • Remove the side piece plate.
  4. Canon Vixia HF R500 Disassembly: passo 4, immagine 1 di 1
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  5. Canon Vixia HF R500 Disassembly: passo 5, immagine 1 di 1
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  6. Canon Vixia HF R500 Disassembly: passo 6, immagine 1 di 1
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  7. Canon Vixia HF R500 Disassembly: passo 7, immagine 1 di 3 Canon Vixia HF R500 Disassembly: passo 7, immagine 2 di 3 Canon Vixia HF R500 Disassembly: passo 7, immagine 3 di 3
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  8. Canon Vixia HF R500 Disassembly: passo 8, immagine 1 di 1
    • Remove the top piece.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 701
