Salta al contenuto principale
Canon Selphy CP720 Screen Replacement
Cosa ti serve
  1. Canon Selphy CP720 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Remove the three 6mm Phillips #1 screws.
  2. Canon Selphy CP720 Screen Replacement: passo 2, immagine 1 di 2 Canon Selphy CP720 Screen Replacement: passo 2, immagine 2 di 2
    • Remove the four 8mm Phillips #1 screws, located in each corner of the device.
  3. Canon Selphy CP720 Screen Replacement: passo 3, immagine 1 di 1
    • Grasp one half of the device's shell in each hand, and pull them apart. They are connected, so don't separate them completely.
  4. Canon Selphy CP720 Screen Replacement: passo 4, immagine 1 di 2 Canon Selphy CP720 Screen Replacement: passo 4, immagine 2 di 2
    • Lift the side panel off to expose the inside of the printer.
  5. Canon Selphy CP720 Screen Replacement: passo 5, immagine 1 di 1
    • Remove the four 8mm Phillips #00 screws that hold the upper circuit board to the shell.
  6. Canon Selphy CP720 Screen Replacement: passo 6, immagine 1 di 1
    • Remove two 8mm Phillips #00 screws from the yellow board.
  7. Canon Selphy CP720 Screen Replacement: passo 7, immagine 1 di 1
    • Remove the two 8mm Phillips #00 screws from the screen.
    • Lift off the circuit board, yellow board, and screen.
  8. Canon Selphy CP720 Screen Replacement: passo 8, immagine 1 di 3 Canon Selphy CP720 Screen Replacement: passo 8, immagine 2 di 3 Canon Selphy CP720 Screen Replacement: passo 8, immagine 3 di 3
    • To separate the screen from the circuit board, grasp the data ribbon cable near the base of the black connector on the circuit board and pull parallel to the surface of the board, toward the screen.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 396
