Salta al contenuto principale
Canon Selphy CP720 Cooling Fan Replacement
Cosa ti serve
  1. Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: passo 1, immagine 1 di 2 Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: passo 1, immagine 2 di 2
    • Remove the four 8mm Phillips #1 screws from the bottom of the printer.
  2. Canon Selphy CP720 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Gently lift the top half of the printer off its base
    • A data ribbon attaches the two halves, so don't pull hard and keep the two halves close together.
  3. Canon Selphy CP720 Cooling Fan Replacement: passo 3, immagine 1 di 3 Canon Selphy CP720 Cooling Fan Replacement: passo 3, immagine 2 di 3 Canon Selphy CP720 Cooling Fan Replacement: passo 3, immagine 3 di 3
    • Remove the side panel by lifting it out.
  4. Canon Selphy CP720 Cooling Fan Replacement: passo 4, immagine 1 di 2 Canon Selphy CP720 Cooling Fan Replacement: passo 4, immagine 2 di 2
    • Unplug the fan from the circuit board by gently pulling on the wire connector at the base of the port.
    • Do not tug on the wires. Slowly increasing force as you pull is the best way to detach the wires.
  5. Canon Selphy CP720 Cooling Fan Replacement: passo 5, immagine 1 di 1
    • Unscrew the two 8mm Phillips #1 screws from the fan.
    • Remove the fan from the panel.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 320
