Salta al contenuto principale
Canon Selphy CP1200 Battery Leads Replacement
Cosa ti serve
  1. Canon Selphy CP1200 Battery Leads Replacement, LCD/Buttons: passo 1, immagine 1 di 1
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 Battery Leads Replacement: passo 2, immagine 1 di 1
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 Battery Leads Replacement: passo 3, immagine 1 di 1
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 Battery Leads Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
  5. Canon Selphy CP1200 Battery Leads Replacement, Motherboard: passo 5, immagine 1 di 1
    • Detach the fan cable from the motherboard.
  6. Canon Selphy CP1200 Battery Leads Replacement: passo 6, immagine 1 di 1
    Compra
    • Detach the ribbon cable leading to the DC in port and battery leads.
    • Tweezers may be useful.
  7. Canon Selphy CP1200 Battery Leads Replacement: passo 7, immagine 1 di 1
    • Unscrew the three 3mm PH000 screws from the motherboard.
  8. Canon Selphy CP1200 Battery Leads Replacement: passo 8, immagine 1 di 1
    • Disconnect the bundled cables leading to the printing mechanism.
  9. Canon Selphy CP1200 Battery Leads Replacement: passo 9, immagine 1 di 1
    • Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
    • Tweezers may be useful due to the limited amount of space.
  10. Canon Selphy CP1200 Battery Leads Replacement, Print Mechanism: passo 10, immagine 1 di 2 Canon Selphy CP1200 Battery Leads Replacement, Print Mechanism: passo 10, immagine 2 di 2
    • Open the side door and depress the ink cassette release.
    • Slide out and remove the ink cassette.
  11. Canon Selphy CP1200 Battery Leads Replacement: passo 11, immagine 1 di 1
    • Unscrew the three 3mm PH000 screws securing the metal plate to the printing mechanism.
  12. Canon Selphy CP1200 Battery Leads Replacement: passo 12, immagine 1 di 1
    • Lift out the print mechanism of the printer case.
  13. Canon Selphy CP1200 Battery Leads Replacement, Battery Leads: passo 13, immagine 1 di 2 Canon Selphy CP1200 Battery Leads Replacement, Battery Leads: passo 13, immagine 2 di 2
    • Lift out the back case plate.
    • Remove the battery leads by lifting it out of its niche in the case.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 643
