Salta al contenuto principale
Canon SX40 HS camera Flash Cover Replacement
Cosa ti serve
  1. Canon SX40 HS camera Flash Cover Replacement, Flash Cover: passo 1, immagine 1 di 2 Canon SX40 HS camera Flash Cover Replacement, Flash Cover: passo 1, immagine 2 di 2
    • Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
    • Repeat to remove the 4 mm black screw located on the right side.
  2. Canon SX40 HS camera Flash Cover Replacement: passo 2, immagine 1 di 1
    • Remove the plastic cover using the iFixIt Plastic Opening Tool.
    • The plastic cover can only be removed in the down position.
  3. Canon SX40 HS camera Flash Cover Replacement: passo 3, immagine 1 di 2 Canon SX40 HS camera Flash Cover Replacement: passo 3, immagine 2 di 2
    • After removing the flash cover, remove the 6 mm silver screw on the right side with a Phillips #00 screwdriver.
    • Repeat to remove the 6 mm silver screw on the left side with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera Flash Cover Replacement: passo 4, immagine 1 di 1
    • Replace the external flash cover or the internal flashlight when all 6 mm silver screws are out.
Conclusione
To reassemble your device, follow Steps 1-4 in reverse order.
John Bui
Membro da: 03/26/15
352 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 824
