Introduzione
User will need spudger, plastic pry tool, and PH00 screwdriver.
Cosa ti serve
Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
Using spudger, lift the tab on the connector and remove the orange ribbon from motherboard (LCD screen is separated from camera).
Using the Phillips 00 screwdriver remove the seven 6mm screws from the housing plate of the LCD screen.
Using the plastic pry tool, remove the motherboard and the flash unit from camera frame (Motherboard and flash unit are separated from camera).
Altre 4 persone hanno completato questa guida.
Un commento
I can't download the pictures from the camera. It doesn't have the card you take out and download the pics. I would plug it in and download from camera to my desktop. It's now saying it can't connect to the camera. I bought a new cord but it's apparently the camera itself. Any way to download the pics I have on the camera?
