Salta al contenuto principale
Canon Powershot SX500 IS Control Dial Replacement
Cosa ti serve
  1. Canon Powershot SX500 IS Control Dial Replacement, Battery: passo 1, immagine 1 di 1
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS Control Dial Replacement: passo 2, immagine 1 di 1
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS Control Dial Replacement: passo 3, immagine 1 di 1
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS Control Dial Replacement, Back Cover: passo 4, immagine 1 di 3 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: passo 4, immagine 2 di 3 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: passo 4, immagine 3 di 3
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS Control Dial Replacement: passo 5, immagine 1 di 1
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS Control Dial Replacement: passo 6, immagine 1 di 1
  7. Canon Powershot SX500 IS Control Dial Replacement: passo 7, immagine 1 di 1
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS Control Dial Replacement: passo 8, immagine 1 di 2 Canon Powershot SX500 IS Control Dial Replacement: passo 8, immagine 2 di 2
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS Control Dial Replacement, Control Dial: passo 9, immagine 1 di 1
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS Control Dial Replacement: passo 10, immagine 1 di 1
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS Control Dial Replacement: passo 11, immagine 1 di 1
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS Control Dial Replacement: passo 12, immagine 1 di 1
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
Conclusione
Un commento
Gracias gracias gracias
edgarlugo20111917 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 454
