Salta al contenuto principale
Canon Powershot SX30 IS Battery/SD Card Door Replacement
Cosa ti serve
  1. Canon Powershot SX30 IS Battery/SD Card Door Replacement, Battery/SD Card Door: passo 1, immagine 1 di 1
    • Open the protective door on the bottom of the camera, and remove the SD card and battery from the camera
  2. Canon Powershot SX30 IS Battery/SD Card Door Replacement: passo 2, immagine 1 di 2 Canon Powershot SX30 IS Battery/SD Card Door Replacement: passo 2, immagine 2 di 2
    • Unscrew the two 2mm screws from the inside of the case
  3. Canon Powershot SX30 IS Battery/SD Card Door Replacement: passo 3, immagine 1 di 2 Canon Powershot SX30 IS Battery/SD Card Door Replacement: passo 3, immagine 2 di 2
    • Remove the plastic backing and the metal front plate from the spring controlled hinge
    • To replace, hold the plastic backing to the metal hinge and screw the plate onto the front of it
Conclusione
That's It! Good Job!
Ellis DeVoe
Membro da: 04/14/15
580 Reputazione
5 Guide realizzate
Cal Poly, Team 5-12, Maness Spring 2015 Membro di Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
4 Membri
5 Guide realizzate
Un commento
What if the existing hinge is broken.....I need to replace the entire door and spring loaded hinge. Ya got instructions for that?
jusanotherhuman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 653
