Salta al contenuto principale
Canon Powershot SX30 IS Back Camera Housing Replacement
Cosa ti serve
  1. Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: passo 1, immagine 1 di 2 Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: passo 1, immagine 2 di 2
    • Position the camera so that the right side is visible as shown.
    • Unscrew the two 6 mm screws shown using a screwdriver.
  2. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 2, immagine 1 di 3 Canon Powershot SX30 IS Back Camera Housing Replacement: passo 2, immagine 2 di 3 Canon Powershot SX30 IS Back Camera Housing Replacement: passo 2, immagine 3 di 3
    • Remove the plastic flap by pressing down on the center of the hinge and pulling on the flap with the spudger.
    • Then, unscrew the lone 6mm screw that was under the plastic flap.
  3. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 3, immagine 1 di 2 Canon Powershot SX30 IS Back Camera Housing Replacement: passo 3, immagine 2 di 2
    • Turn the camera so that the bottom is visible, as shown.
    • Unscrew the three 4mm screws shown red using a screwdriver.
    • Unscrew the single 6mm screw.
    • Do not touch the screw shown yellow, removal is unnecessary. (Note: the top right yellow screw should be removed)
  4. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 4, immagine 1 di 1
    • Turn the camera so the back side is visible, as shown.
    • Unscrew the two 6mm screws.
  5. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 5, immagine 1 di 1
    • Gently remove the back cover using the spudger.
    • Exercise caution, as the wire inside is fragile.
  6. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 6, immagine 1 di 2 Canon Powershot SX30 IS Back Camera Housing Replacement: passo 6, immagine 2 di 2
    • Detach the wire by lifting the small black bar that holds it to the main body of the camera.
  7. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 7, immagine 1 di 1
    • Attach the new cover onto the camera.
  8. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 8, immagine 1 di 1
    • Reattach the wire to your new rear casing.
  9. Canon Powershot SX30 IS Back Camera Housing Replacement: passo 9, immagine 1 di 1
    • Close the back cover, and re-insert appropriate screws.
Conclusione
Altre 2 persone hanno completato questa guida.
Ellis DeVoe
Membro da: 04/14/15
580 Reputazione
5 Guide realizzate
Cal Poly, Team 5-12, Maness Spring 2015 Membro di Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,347
