Introduzione
If the tripod screw mount in the adapter for a tripod becomes overused, it can split or become stripped. This guide will explain how to remove and replace the tripod screw mount from the Canon PowerShot SX10 IS .
Cosa ti serve
Open the door. Release the catch by sliding it towards the side of the camera.
Then slide the door towards the front of the camera.
Remove two cables connected to the motherboard.
Use thin tweezers to push down on the clear piece and slide it out. At this point half of the clear piece should be free.
Remove one screw that is holding down the middle of the clear piece to the body of the camera. The whole structure with wires will swing out.
Using the iFixit opening tool, gently pry along the top edge of the front casing.
Move to the right side of the camera and gently pry at the top and bottom areas of this part of the casing. The front casing will come free once it has been pried here.
The front casing will be able to slide away from the body of the camera.
Remove one screw that holds both a black cable and part of the tripod mount.
The silver bracket and black cable will pop right off.
