Salta al contenuto principale
Canon Powershot SD880 Top Panel Replacement
Cosa ti serve
  1. Canon Powershot SD880 Top Panel Replacement, Back Cover: passo 1, immagine 1 di 3 Canon Powershot SD880 Top Panel Replacement, Back Cover: passo 1, immagine 2 di 3 Canon Powershot SD880 Top Panel Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 Top Panel Replacement, Top Panel: passo 2, immagine 1 di 2 Canon Powershot SD880 Top Panel Replacement, Top Panel: passo 2, immagine 2 di 2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
Conclusione
Robert Manno
Membro da: 01/05/11
432 Reputazione
4 Guide realizzate
Cal Poly, Team 13-3, Forte Winter 2011 Membro di Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,043
