Salta al contenuto principale
Canon Powershot SD880 LCD Display Replacement
Cosa ti serve
  1. Canon Powershot SD880 LCD Display Replacement, Back Cover: passo 1, immagine 1 di 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: passo 1, immagine 2 di 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 LCD Display Replacement, LCD Display: passo 2, immagine 1 di 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: passo 2, immagine 2 di 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: passo 2, immagine 3 di 3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
Conclusione
Ben Tupas
Membro da: 01/13/11
329 Reputazione
3 Guide realizzate
Cal Poly, Team 13-3, Forte Winter 2011 Membro di Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Membri
8 Guide realizzate
1Commento della guida
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,518
