Salta al contenuto principale
Canon Powershot SD880 Front Cover Replacement
Cosa ti serve
  1. Canon Powershot SD880 Front Cover Replacement, Back Cover: passo 1, immagine 1 di 3 Canon Powershot SD880 Front Cover Replacement, Back Cover: passo 1, immagine 2 di 3 Canon Powershot SD880 Front Cover Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 Front Cover Replacement, Front Cover: passo 2, immagine 1 di 3 Canon Powershot SD880 Front Cover Replacement, Front Cover: passo 2, immagine 2 di 3 Canon Powershot SD880 Front Cover Replacement, Front Cover: passo 2, immagine 3 di 3
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
Conclusione
Robert Manno
Membro da: 01/05/11
432 Reputazione
4 Guide realizzate
Cal Poly, Team 13-3, Forte Winter 2011 Membro di Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,817
