Salta al contenuto principale
Canon Powershot SD550 LCD Screen Replacement
Vivian Su
Vivian Su e 5 altri collaboratori
Ultimo aggiornamento il June 10, 2022
20 - 30 minuti
Facile
Guida In Evidenza
Introduzione
Vai al passo 1
A cracked LCD screen is a prevalent problem in digital cameras. But, before you spend money on a new LCD screen, make sure the camera still works by taking a few pictures and uploading them to your computer. A cracked LCD will not affect the quality of the pictures. You do not want to try to replace the LCD if something else is broken.
Cosa ti serve
Strumenti
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. Canon Powershot SD550 LCD Screen Replacement, Outer Case: passo 1, immagine 1 di 1
    • Remove the battery and SD card from the camera.
  2. Canon Powershot SD550 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the three 3.8 mm screws from the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 LCD Screen Replacement: passo 3, immagine 1 di 3 Canon Powershot SD550 LCD Screen Replacement: passo 3, immagine 2 di 3 Canon Powershot SD550 LCD Screen Replacement: passo 3, immagine 3 di 3
    • Remove the 3.2 mm screw from the right side of the camera.
    • Remove the 2.2 mm screw from the right side of the camera.
    • One of these screws is hidden under the USB port cover.
    • Lift the side panel off.
    • Remove the 1.8 mm screw from underneath the side panel.
  4. Canon Powershot SD550 LCD Screen Replacement: passo 4, immagine 1 di 3 Canon Powershot SD550 LCD Screen Replacement: passo 4, immagine 2 di 3 Canon Powershot SD550 LCD Screen Replacement: passo 4, immagine 3 di 3
    • Remove the two 2.2 mm screws from the left side of the camera.
    • Lift the plate from the camera.
  5. Canon Powershot SD550 LCD Screen Replacement: passo 5, immagine 1 di 3 Canon Powershot SD550 LCD Screen Replacement: passo 5, immagine 2 di 3 Canon Powershot SD550 LCD Screen Replacement: passo 5, immagine 3 di 3
    • Gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 LCD Screen Replacement: passo 6, immagine 1 di 3 Canon Powershot SD550 LCD Screen Replacement: passo 6, immagine 2 di 3 Canon Powershot SD550 LCD Screen Replacement: passo 6, immagine 3 di 3
    • Remove the front of the camera body.
    • Be sure to keep track of the rubber ring.
  7. Canon Powershot SD550 LCD Screen Replacement, LCD Screen: passo 7, immagine 1 di 3 Canon Powershot SD550 LCD Screen Replacement, LCD Screen: passo 7, immagine 2 di 3 Canon Powershot SD550 LCD Screen Replacement, LCD Screen: passo 7, immagine 3 di 3
    • Peel the navigation buttons from the button panel and set them aside.
    • To free the LCD display, remove the 2.9 mm screw in the top left corner.
    • Rotate the screen clockwise until it lifts away from the camera.
    • There are two ribbon cables attached to the rear of the screen. Do not try to pull the screen off at this point.
  8. Canon Powershot SD550 LCD Screen Replacement: passo 8, immagine 1 di 2 Canon Powershot SD550 LCD Screen Replacement: passo 8, immagine 2 di 2
    • To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
    • After disconnecting both cables, pull the screen away from the camera to remove it.
Conclusione
Altre 2 persone hanno completato questa guida.
Vivian Su
Membro da: 04/17/11
31 Reputazione
1 Guida realizzata
Cal Poly, Team 18-23, Garner Spring 2011 Membro di Cal Poly, Team 18-23, Garner Spring 2011
CPSU-GARNER-S11S18G23
5 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,418
