Salta al contenuto principale
Canon Powershot S200 Motherboard Replacement
Cosa ti serve
  1. Canon Powershot S200 Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Canon Powershot S200 Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Motherboard Replacement: passo 2, immagine 1 di 2 Canon Powershot S200 Motherboard Replacement: passo 2, immagine 2 di 2
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove battery from the camera.
  4. Canon Powershot S200 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 1
    • Remove the lanyard.
  5. Canon Powershot S200 Motherboard Replacement: passo 5, immagine 1 di 1
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Motherboard Replacement: passo 9, immagine 1 di 1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Motherboard Replacement: passo 10, immagine 1 di 2 Canon Powershot S200 Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Motherboard Replacement: passo 11, immagine 1 di 2 Canon Powershot S200 Motherboard Replacement: passo 11, immagine 2 di 2
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Motherboard Replacement: passo 13, immagine 1 di 1
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Canon Powershot S200 Motherboard Replacement: passo 15, immagine 1 di 2 Canon Powershot S200 Motherboard Replacement: passo 15, immagine 2 di 2
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Canon Powershot S200 Motherboard Replacement: passo 16, immagine 1 di 1
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Motherboard Replacement: passo 17, immagine 1 di 1
    • Remove the motherboard from the main frame of the camera body.
Conclusione
Orlando Zuniga
Membro da: 04/14/11
11 Reputazione
1 Guida realizzata
Cal Poly, Team 20-70, Walters Spring 2011 Membro di Cal Poly, Team 20-70, Walters Spring 2011
CPSU-WALTERS-S11S20G70
5 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,879
