Salta al contenuto principale
Canon Powershot Pro1 Motherboard Replacement
Cosa ti serve
  1. Canon Powershot Pro1 Motherboard  Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Motherboard  Replacement: passo 2, immagine 1 di 1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Motherboard  Replacement: passo 3, immagine 1 di 1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Motherboard  Replacement: passo 4, immagine 1 di 1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Motherboard  Replacement, Motherboard: passo 5, immagine 1 di 3 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: passo 5, immagine 2 di 3 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: passo 5, immagine 3 di 3
    • Open the screen to access the underside of the camera.
  6. Canon Powershot Pro1 Motherboard  Replacement: passo 6, immagine 1 di 3 Canon Powershot Pro1 Motherboard  Replacement: passo 6, immagine 2 di 3 Canon Powershot Pro1 Motherboard  Replacement: passo 6, immagine 3 di 3
    • Using the Phillips #000 screwdriver:
    • Remove two 1.00 mm screws under the viewfinder.
    • Remove one screw in the battery compartment.
    • Remove five screws on the bottom of the camera.
    • Remove one screw on the left side of the camera (opposite the battery compartment).
  7. Canon Powershot Pro1 Motherboard  Replacement: passo 7, immagine 1 di 3 Canon Powershot Pro1 Motherboard  Replacement: passo 7, immagine 2 di 3 Canon Powershot Pro1 Motherboard  Replacement: passo 7, immagine 3 di 3
    • Completely detach the cover from the motherboard.
    • Lift the inside cover to reveal the motherboard.
    • Detach the bottom right ribbon cable from the motherboard.
  8. Canon Powershot Pro1 Motherboard  Replacement: passo 8, immagine 1 di 2 Canon Powershot Pro1 Motherboard  Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Lift up the gold insulation cover to reveal the motherboard.
    • Use tweezers and an iFixit opening tool, detach any wire connectors and ribbon cables from the motherboard.
  9. Canon Powershot Pro1 Motherboard  Replacement: passo 9, immagine 1 di 3 Canon Powershot Pro1 Motherboard  Replacement: passo 9, immagine 2 di 3 Canon Powershot Pro1 Motherboard  Replacement: passo 9, immagine 3 di 3
    • Once detached from all connectors and ribbon cables, remove the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,200
