Salta al contenuto principale
Canon Powershot Pro1 Lens Replacement
Cosa ti serve
  1. Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: passo 1, immagine 1 di 2 Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: passo 1, immagine 2 di 2
    • Have the lens of the camera facing upwards.
    • Find the red plastic ring.
    • Look for two small opening above the red plastic ring.
    • Reference to the left of the picture and you will see the orange square.
  2. Canon Powershot Pro1 Lens Replacement: passo 2, immagine 1 di 3 Canon Powershot Pro1 Lens Replacement: passo 2, immagine 2 di 3 Canon Powershot Pro1 Lens Replacement: passo 2, immagine 3 di 3
    • Remove the plastic ring that has a red strip.
    • Remove the 1.5 mm Phillips #1 screws which lie underneath the ring.
  3. Canon Powershot Pro1 Lens Replacement: passo 3, immagine 1 di 3 Canon Powershot Pro1 Lens Replacement: passo 3, immagine 2 di 3 Canon Powershot Pro1 Lens Replacement: passo 3, immagine 3 di 3
    • Place the camera on its back with the lens facing upwards as shown in the image
    • Remove the additional 1.5 mm Phillip #1 screw from underneath the lens cover
    • Remove the screw by turning the Philip driver counterclockwise.
    • By removing the screw, you will be able to remove the cover lens.
  4. Canon Powershot Pro1 Lens Replacement: passo 4, immagine 1 di 1
    • Use the nylon spudger to remove the ring holding the lens in place.
    • Pull gently until the lens ring snaps off.
  5. Canon Powershot Pro1 Lens Replacement: passo 5, immagine 1 di 1
    • Refer to the left-hand pictere to see what the len's ring looks like.
  6. Canon Powershot Pro1 Lens Replacement: passo 6, immagine 1 di 3 Canon Powershot Pro1 Lens Replacement: passo 6, immagine 2 di 3 Canon Powershot Pro1 Lens Replacement: passo 6, immagine 3 di 3
    • Take out the lens once the plastic ring is removed
    • Hold the outer layer of the lens to not create smudges on it.
    • Replace the lens and follow the instruction in reversed order to reassemble the camera.
Conclusione
Un commento
Hi, can you do a guide on how to repair the diaphragm?
OTVaL - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 78
Tutti i Tempi: 2,460
