Salta al contenuto principale
Canon Powershot Pro1 LCD Screen Replacement
Cosa ti serve
  1. Canon Powershot Pro1 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 LCD Screen Replacement: passo 2, immagine 1 di 1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 LCD Screen Replacement, LCD screen: passo 5, immagine 1 di 1
    • Open up the LCD screen.
  6. Canon Powershot Pro1 LCD Screen Replacement: passo 6, immagine 1 di 2 Canon Powershot Pro1 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Remove the 1.2 mm Phillips #0 screws on the left and right side of the LCD.
    • Using the Phillips #000 screwdriver, remove the screws on the right (you need to rotate the screen to access the screws on the right, and you will see one on each corner).
  7. Canon Powershot Pro1 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove the back cover of the LCD screen (has “Canon” written on it).
  8. Canon Powershot Pro1 LCD Screen Replacement: passo 8, immagine 1 di 3 Canon Powershot Pro1 LCD Screen Replacement: passo 8, immagine 2 di 3 Canon Powershot Pro1 LCD Screen Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Now you will see an exposed circuit board and the backside of the LCD.
    • Fold back the plastic covering and remove the highlighted ribbon cables with tweezers.
  9. Canon Powershot Pro1 LCD Screen Replacement: passo 9, immagine 1 di 1
    • Using the nylon spudger, pry the LCD off the screen cover.
    • You can now separate the LCD from the camera.
    • Don't use a metal spudger as this could cause damage to the device.
Conclusione
1Commento della guida
Hi, where do I get a replacement lcd screen for this is camera?
Dog EatDog - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,084
