Salta al contenuto principale
Canon Powershot ELPH 100 HS Memory Card Replacement
  1. Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: passo 1, immagine 1 di 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: passo 1, immagine 2 di 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Memory Card Replacement: passo 2, immagine 1 di 2 Canon Powershot ELPH 100 HS Memory Card Replacement: passo 2, immagine 2 di 2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: passo 3, immagine 1 di 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: passo 3, immagine 2 di 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: passo 3, immagine 3 di 3
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
Conclusione
Lillia
Membro da: 03/17/15
255 Reputazione
2 Guide realizzate
Un commento
my internal card reader hardware is not functional
can i replace it somehow
s l - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,028
