Salta al contenuto principale
Canon Powershot ELPH 100 HS Battery Replacement
  1. Canon Powershot ELPH 100 HS Battery Replacement, Battery: passo 1, immagine 1 di 3 Canon Powershot ELPH 100 HS Battery Replacement, Battery: passo 1, immagine 2 di 3 Canon Powershot ELPH 100 HS Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Battery Replacement: passo 2, immagine 1 di 2 Canon Powershot ELPH 100 HS Battery Replacement: passo 2, immagine 2 di 2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
Conclusione
Lillia
Membro da: 03/17/15
267 Reputazione
2 Guide realizzate
3 Commenti
What if the internal time/date battery is bad? A fully charged battery will drain crazy fast because the rechargeable internal No longer charges. Is there a fix?
S Silvia - Replica
Hi @ssilvia, there isn't a guide specifically for the CMOS or coin cell battery replacement but the Canon Powershot ELPH 100 HS Outer Case Replacement guide has an image that confirms there is a coin cell battery. It looks like you should be able to access and replace it. The photo is a little blurry so I couldn't read the specific size. I hope this helps or at least this might get you started on the repair. Thanks!
Sarah Westberg -
What if the battery cover (gray tab) is broken?? I accidentally ripped it off.
Jade - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 41
Tutti i Tempi: 2,004
