Salta al contenuto principale
Canon PowerShot SX520 HS Motherboard Replacement
Cosa ti serve
  1. Canon PowerShot SX520 HS Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS Motherboard Replacement: passo 2, immagine 1 di 1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS Motherboard Replacement, Back Face: passo 3, immagine 1 di 3 Canon PowerShot SX520 HS Motherboard Replacement, Back Face: passo 3, immagine 2 di 3 Canon PowerShot SX520 HS Motherboard Replacement, Back Face: passo 3, immagine 3 di 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS Motherboard Replacement: passo 5, immagine 1 di 2 Canon PowerShot SX520 HS Motherboard Replacement: passo 5, immagine 2 di 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS Motherboard Replacement: passo 6, immagine 1 di 1
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS Motherboard Replacement, LCD Screen: passo 7, immagine 1 di 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS Motherboard Replacement: passo 8, immagine 1 di 1
    • Carefully pop out the LCD screen with your fingers.
  9. Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: passo 9, immagine 1 di 3 Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: passo 9, immagine 2 di 3 Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: passo 9, immagine 3 di 3
    • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
    • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • After all 8 screws are removed, pull the metal plate out with your fingers.
  10. Canon PowerShot SX520 HS Motherboard Replacement, Lens: passo 10, immagine 1 di 1
    • Unlcip the large cable by pulling up on the metal part with your finger.
    • Slide out the 2 smaller cables with your fingers.
  11. Canon PowerShot SX520 HS Motherboard Replacement: passo 11, immagine 1 di 1
    • Lift up the lens by grabbing the sides with your fingers.
  12. Canon PowerShot SX520 HS Motherboard Replacement, Motherboard: passo 12, immagine 1 di 1
    • Remove 1-2.5 mm screw using a Phillips #000 screwdriver.
  13. Canon PowerShot SX520 HS Motherboard Replacement: passo 13, immagine 1 di 2 Canon PowerShot SX520 HS Motherboard Replacement: passo 13, immagine 2 di 2
    • Disconnect the two orange serial cables at the top of the motherboard using your fingers.
    • Gently remove the motherboard using your fingers.
    • Too much force will break the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Kyle Crowley
Membro da: 09/22/15
337 Reputazione
3 Guide realizzate
Baylor, Team 4-4, Williams Fall 2015 Membro di Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,005
