Introduzione
If you crack the lens of your camera or if it is not functioning properly, this guide may be for you. This guide will help you remove and replace the lens.
Cosa ti serve
Using your fingers, slide the battery compartment door to the right until it unlocks.
Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
After all 8 screws are removed, pull the metal plate out with your fingers.
Unlcip the large cable by pulling up on the metal part with your finger.
Slide out the 2 smaller cables with your fingers.
Altre 6 persone hanno completato questa guida.
Un commento
guide is unfinished; dropping to the point of lens group extraction without going on further. I found it, useless.
