Salta al contenuto principale
Canon PowerShot SX520 HS LCD Screen Replacement
Cosa ti serve
  1. Canon PowerShot SX520 HS LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS LCD Screen Replacement: passo 2, immagine 1 di 1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: passo 3, immagine 1 di 3 Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: passo 3, immagine 2 di 3 Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: passo 3, immagine 3 di 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS LCD Screen Replacement: passo 5, immagine 1 di 2 Canon PowerShot SX520 HS LCD Screen Replacement: passo 5, immagine 2 di 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS LCD Screen Replacement: passo 6, immagine 1 di 1
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS LCD Screen Replacement, LCD Screen: passo 7, immagine 1 di 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS LCD Screen Replacement: passo 8, immagine 1 di 1
    • Carefully pop out the LCD screen with your fingers.
Conclusione
Lisa Choe
Membro da: 09/22/15
460 Reputazione
3 Guide realizzate
Baylor, Team 4-4, Williams Fall 2015 Membro di Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,047
