Introduzione
Replace the func. set turn dial of the Canon PowerShot SX50 HS.
Cosa ti serve
Locate the battery compartment on the bottom of the camera.
Push the latch on the outside of the battery door to the right to get to the battery pack inside.
Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
Remove the four Phillips #000 screws, length 3 mm, attaching the metal panel to the inside of the back encasement.
Altre 2 persone hanno completato questa guida.
2 Commenti
Interested to know where I can buy the switch/ribbon assembly for that function dial?
I appreciated the clear instructions and photos. Couldn’t be any better. Now I would like to know where to purchase the dial assembly.
